Deleted member 26818
A problem with that scenario, is you don’t know what the stop?start button does.Ironically I think our ‘wires have been crossed’ (don’t trip over that pun)
I was talking about if I was going to put it in front of the starter motor as obviously the starter motor will turn every time. Yes I agree that the button won’t have the same effect.
Other than the belittling yes your contributions have been some what helpful. I know these are complex machines but what I am looking to do is not. I don’t intend to intercept a data line. From my understanding of it is that when you push the button it sends an electrical signal to the computer telling it to start. If I close the relay it was stop that signal from being able to get to the computer. Which is exactly the same as just not pushing the button. I can’t understand how this is so complex and would damage anything. It’s either sending pulse voltage or not.
I’m not saying you’re wrong, but fitting it this way, can you explain how this could be damaging to anything and what could go wrong? (Assuming I’ve metered and found the right cable) I can’t see that putting a closed relay is any different to not pushing the button.
With the relay closed if a thief pressed the button that signal would simply just not reach the computer, same as before he pressed the button. No?
It may well be that the button just sends a signal to the ECU, and the ECU then decides what action to take.
If the engine is not running, the ECU starts the engine.
If the engine is running, the ECU stops the engine.
Disabling the start/stop button may mean the ECU never decides to stop the engine.
