W
woko
Hi, I need A little info in how you fix hanger bolts to a steel fabricated roof. The roof is tapezoidal sheets sandwiching insulation.I was told by the Hilti rep to use Hanger bolts straight through the roof into the steel purlin. Do you then put timber along the purlin to hold the bolts?
I was told I can't use tapezoidal fixings as the top sheet isn't strong enough for the wind loading.
Any help with this would be appreciated.
