fixing heights domestic | on ElectriciansForums
Discuss fixing heights domestic in the Domestic Electrician Forum area at ElectriciansForums.net
England
Hi 2nd attempt writing this! As some of know wiring new house for family member. After great discussion / debate on another thread re those damn extractor fans with timers etc. I've decided to go with wall mounted 1g light switch outside each en suite (customers request as doesn't like pull switches) and the 3 pole isolation switch at low level 450mm as opposed to high level or above the door. Will that comply with BS7671 Regs? I'm going to use a fan whereby the manufacture will not insist on a 3amp fuse.
I'd already chopped in a deep box for a shaver point in 1 en suite at face height when the penny dropped that I had in fact installed it too high. I have now installed it at no higher than 1200mm. I take it height restrictions includes shaver points also.
Now for wall mounted TV points. Many wall mounted TV points to be installed, like a damn hotel! I've installed the boxes so as no higher than 1200mm. I would like to mount them a bit higher really so as to hide the boxes behind the wall mounted TV when installed. Your thoughts,experience appreciated.
Family member or customer?
As for where to put accessories.............the section on the eic says " deviations from 7671" or something like that.
Put them where you want.......
As for where to put accessories.............the section on the eicr says " deviations from 7671" or something like that.
Yes Family...family member doesn't want pull switches although I did say customer, well spotted though lol. As it's a new build, should there be any deviations?
As you're doing a new install, no, no deviations from BS7671, but then this is building regs (part M). As the iso is for servicing (in theory) then mount above door, otherwise we'll be mounting extractor fans between 450 and 1200 as well!
Thanks for reply.....If mounted higher, i was going to install them so as to reach them standing on the floor (no steps) The idea of fitting them lower (skt height) so as to be less obstructive.
fans will be ceiling type not in line
Just because it's a newbuilds doesn't exclude it from any deviations........customers have their own idea of what they want and sometimes that conflicts with the regs.....
As for not wanting pull switches, why not go with sensors, saves kids leaving the bathroom lights on.
Fan iso switch in loft, seen it many times.....lazy option but you can't count for customers not wanting trunk or after install plastering.
How is it lazy? The idea behind it is for maintenance.
What is the point in having one at all if your not going to have one local to the fan?
Reply to fixing heights domestic in the Domestic Electrician Forum area at ElectriciansForums.net
