Fixing of trunking/wall mounted isolation switches | on ElectriciansForums
Discuss Fixing of trunking/wall mounted isolation switches in the UK Electrical Forum area at ElectriciansForums.net
stratplus
Hi all, when fixing the above into plasterboard do you ever use raw plugs or do you always use plasterboard fixings?
Red wall plugs are a no-no, they seem to work, but soon fall out or end up going round and round when you screw the screw in. You can get away with the metal 'thorsman' (other-makes-may-be-available) screw in jobbies for static loads, such as the trunking, unless its 50x50 full to the brim. As Eng54 says, toggles are better, especially for isolators which will have monkeys dangling off them every so often.
I always use wall anchors but noticed a spark using red plugs and screws!!! I questioned him, said he's always done it. I put a screw driver on one of the screw expecting it to spin but it was tight as! Hence my question on here.
when you drill 5.5mm and use a red plug it goes in nice and tight. does the job with self adhesive trunking, when fixing isolator or a socket better use plasterboard plugs or try screw it to a batten underneath.
Reply to Fixing of trunking/wall mounted isolation switches in the UK Electrical Forum area at ElectriciansForums.net
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
However it's done, you need to have a guarantee of no sharp/unprotected edges that can damage the insulation. Personally, I'm not that impressed...
