Fixing of trunking/wall mounted isolation switches | Page 2 | on ElectriciansForums
Discuss Fixing of trunking/wall mounted isolation switches in the UK Electrical Forum area at ElectriciansForums.net
stratplus
Hi all, when fixing the above into plasterboard do you ever use raw plugs or do you always use plasterboard fixings?
I'm a big fan of Sikaflex which is basically an adhesive. We use it on trunking along with a few screws. The majority of our installations are data cabling but I'm sure it would also work for smaller power cabling as well. It works even better if you fit your trunking at least a day before you put the cabling in.
The thing with BS7671, is there is quite a bit about good workmanship, taking note of manufacturer's instructions, choosing suitable equipment for the conditions even ensuring that an item meets the appropriate British Standards for the use that item is being put to.
As far as I'm aware rawl plugs are designed to be used in masonary, not to be used in plasterboard.
It may be that using Rawlplugs in plasterboard would not comply with BS7671.
I'd never use standard rawlplugs on plasterboard. And I have never met a spark who would.
Screwing into the batten is best but if you have to go into the plasterboard then Twirly plasterboard fixings are okay, but the best fixings I find are the brolly type.
Reply to Fixing of trunking/wall mounted isolation switches in the UK Electrical Forum area at ElectriciansForums.net
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
However it's done, you need to have a guarantee of no sharp/unprotected edges that can damage the insulation. Personally, I'm not that impressed...
