Fixing unsheathed twin and earth | Page 2 | on ElectriciansForums
Discuss Fixing unsheathed twin and earth in the UK Electrical Forum area at ElectriciansForums.net
Spudders
Maidstone
Under my floorboards I have a short section of twin and earth which is unsheathed. The outer grey coating has been stripped over a 10 cm length and the two inner red and black coatings have been stripped over a 2-3cm length to expose the copper cables. The cable has no marking to indicate the size but the copper is stranded and I'd say it's 6mm cable (from my very limited experience). I don't know where the cable runs to but there isn't an electric shower and it's not to the cooker/hob so it can only be for plug sockets.
What is my best course of action? I've wrapped the exposed cable with electrical tape and turned the power off as the house is being renovated and I'm staying at my parents while it's being finished. Will I need to cut the wire and fit a junction box and if so I presume a 60a maintenance free one?
The cable must have been in this state for some time. I only noticed when I was securing a squeaky floorboard and moved a cable out of harm's way only to hear a pop from the other side of the room where I tugged on it and caused the exposed copper to touch the earth wire.
Many thanks
Thank you for your replies and advice. I'll take a look at the earth tomorrow. The cable isn't quite as chunky as another bit of 6mm I've got in the house but it's a a lot bigger than the 2.5mm. The cable itself didn't give any indication as to the size, it just says "Volex Salford".
I've got an electrician coming soon to wire the cooker/hob cables into the fuse board but that won't be for a couple of weeks. I was hoping this would be a quick and straightforward job I could do myself before then so I could get the floorboards fixed in place and carpets laid but I can wait for him to check it out if needs be.
Given that the cable isn't broken the important thing is to protect it from touching and shorting if it may still be live. You seem to have managed that temporarily, but will need something more pemanent before the carpet goes down.
I wonder whether If it could be put into one of the old circular junction boxes, then that may be enough - the point of a maintenance free junction box is that the terminals can't come loose - but in this case there are no 'terminations' as the cable is still complete. The point is to safely insulate the cable.
But if the electrician will be working then he will be signing things off so it should probably be his decision. It might be a case of asking the electrician to pop in earlier, even if briefly - it shouldn't be a long job.
Good shout about using J201 joint box, the cable is still in one piece.
I would say sixties, seventies cable. It looks like a solid earth so I would say, metric, 4.0mm, maybe.
It's interesting, Volex was the trade name of Ward and Goldstone, a big manufacturer based in Salford. Their cable wasn't bad but their general accessories were known by us as 'cheap Ward and Goldstone crap'....the equivalent of Proteus today, I suppose, but they didn't get into distribution equipment. No cheap circuit breakers around in those days.
Just a point.
Reply to Fixing unsheathed twin and earth in the UK Electrical Forum area at ElectriciansForums.net
Twin and earth on its own isnt going to meet the requirements for burial. Why not use Swa ?
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
