Flashing PIR Floodlight problem | on ElectriciansForums
Discuss Flashing PIR Floodlight problem in the UK Electrical Forum area at ElectriciansForums.net
R
Rudie
Hi,
I have an external floodlight without a switch on the inside. a few months back it started to come on, then go off for like 3 seconds, then come back on again, then off, then on. i changed the unit and the new one was fine. then the same started to happen again with the new one. surely i cant have had 2 bad floodlights or is there anything else i can check? there is nothing moving within range to set off the pir. as a last resort i have had to remove the bulb so it doesnt keep going off all night!
Thanks in advance.
does it permanently in the dark once activated. if i remove the bulb at night after switching off the circuits from mains and replace bulb during the day, its ok...until activated during the night
it's either a faulty PIR or , less likely, something in the house causing the problem. this is doubtful as the new one would not have worked for a while. suggest replacing with a timeguard unit. the b&q and other cheapo one's are crap.
i have the same pir unit on the front of the house and touch wood, that ones ok, but thats fed from a switch so can turn that one off by itself. the problematic pir was replaced with one from argos
Reply to Flashing PIR Floodlight problem in the UK Electrical Forum area at ElectriciansForums.net
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
Haha! Normally I would sweat just reading those posts! I'm not that steady on my feet when I'm standing on the ground, so ladders are hateful for...
