Flashing PIR Floodlight problem | Page 3 | on ElectriciansForums
Discuss Flashing PIR Floodlight problem in the UK Electrical Forum area at ElectriciansForums.net
R
Rudie
Hi,
I have an external floodlight without a switch on the inside. a few months back it started to come on, then go off for like 3 seconds, then come back on again, then off, then on. i changed the unit and the new one was fine. then the same started to happen again with the new one. surely i cant have had 2 bad floodlights or is there anything else i can check? there is nothing moving within range to set off the pir. as a last resort i have had to remove the bulb so it doesnt keep going off all night!
Thanks in advance.
Reply to Flashing PIR Floodlight problem in the UK Electrical Forum area at ElectriciansForums.net
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
Haha! Normally I would sweat just reading those posts! I'm not that steady on my feet when I'm standing on the ground, so ladders are hateful for...
