OP
aidley
Yes was just wondering if a spurred off extractor could effect my readings before I have to put new legs in
Discuss flat down neutral to earth reading in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
30 megohms and similar l to e
Yes except neutral to earth which is zero
Whatever it takes its a mutual exchange on.a social housing house
So that could bring the n-e down? Hopefully it is that dont really fancy putting a fresh leg in
I have isolated the leg thats down split the ring and put it on 2 20amp breakers so I can leave it safe till Monday!The leg thats down seems to run close to tge extractor looked inside and there is 1 x1.5 but no sign of a fcu so assumed it was part of the lighting circuit! If it has been spurred off the ring could this give me the strange readings
Well you need one as you have to prove the RCD is operating at the correct fault current.
Reply to flat down neutral to earth reading in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
