T
TwoSocks
Hello folks, I'm an electrician in training and this is my first post in the this forum so take it easy if I mess anything up.
I've had a lot of trouble with the lighting in my flat with dimmer switches controlling GU10 Hallogen bulbs, with the main problem that each module is being overloaded. I have 50w bulbs in and have been told that the midule needs 1 and a half times the capacity thresh hold per dimmer switch. I had a trained electrician in to look at the problem and we've been able to work out that I'd have to get a much higher capacity module for each dimmer to sort the problem. So I've decided to scrap the dimmers and just go for a gang switch instead. I installed a single swich in one room today with no problems and have ordered a 3 gang switch to install later.
The problem has been that after installing the single gang in my bedroom the power to the ensuite in the same room seems to have completely died. I can't get a reading from any of the wires. I'm not sure if it could be related but with the bathroom there is an extractor fan connect to the gang switch.
Any help would be appreciated and I can get some pictures up if it would help, cheers.
