Flat plate screwless sockets etc. | on ElectriciansForums
Discuss Flat plate screwless sockets etc. in the UK Electrical Forum area at ElectriciansForums.net
kingeri
Yorkshire
Evening all. I have a job coming up to replace all the white accessories with flat plate screwless ones. I haven't used these before, just wanted any heads up from anyone who has. Is there anything special I need to do or any problems I might experience?
Just replaced a load with GET/Schneider screwless flatplate. No problems with existing backboxes. Costly stuff, but classy. Simple job.
I try and talk my customers out of them! They look great the first time they go click.....see what they look like after they've been off and back on a few times.
Do not loose the 3.5mm pins supplied as they are flat head to fit into the recess of theplate If you use countersunk pins the faceplates do not fit on.
35mm back boxes are nice but not essential
perfect flat walls are essential!
Reply to Flat plate screwless sockets etc. in the UK Electrical Forum area at ElectriciansForums.net
When I first started, I stripped out a house for a rewire and got my hands on a switch with an inlay and transparent cover. Filled it in with...
And if it's a garage then use metal clad accessories.
