on my job i started today
a different contractor has done the mains (100a 3ph head>>100a 3ph iso>>63a ryefeild>> meters>>then into a 100a isolator switch (no fuse just a 100a main switch)
then I am responsible for the swa from here and then to consumer unit within the flats and the flat installs etc
should the isolator switch be fused- or is it ok to rely on the ryefeild fuse?
ta
ta
