Flat wood bit stuck in impact driver | Page 2 | on ElectriciansForums
Discuss Flat wood bit stuck in impact driver in the UK Electrical Forum area at ElectriciansForums.net
Anyone ever had a long SDS bit totally jammed in a stone/granite type wall - and abandoned it ?? :D
I was drilling down through my concrete kitchen floor behind the kitchen cabinets to replace the water main and got a 3ft 20mm drill bit stuck but eventually managed to get it free by using a 25mm drill bit and drilling down beside it, at some cost to the 25mm bit, but I had spent two days getting that far and was not going to try again.
last time i had a little drift, was in a gale. mooring broke. boat ended up on the rocks. all goes to prove, if it's got ---- or floats, it's gonna cost.
I sheared off a bit holder in my makita impact driver. I disassembled the chuck and got the broken bit out, but it never went back together the same, the bits kept falling out the end! . Thankfully it was 11 months and 3 weeks old so it went back to makita who very kindly fitted a new chuck!
Reply to Flat wood bit stuck in impact driver in the UK Electrical Forum area at ElectriciansForums.net
I would say it is more about the bits than the torque of the drill. I use high quality Fisch auger bits for drilling out mortices and peg holes...
The company Liteplan do replacement modules: Liteplan – The UK's largest emergency lighting component supplier. - https://www.liteplan.com/ This...
