Flexishield cable | Page 2 | on ElectriciansForums
Discuss Flexishield cable in the UK Electrical Forum area at ElectriciansForums.net
atm84
Does anyone know if the aluminium sheath is earthed. The way the manufacturers talk it negates the need to protect circuits by RCD but as the sheath is not earthed and can be penetrated by a nail or screw, i can't really see the benefit of the stuff other than for interference.
I guess its quite expensive too.
On my current project in central London, 275 very expensive apartments are being cabled in fp200. I assume the designer has a reason for this. Note that my company are not installing this, we are purely data and AV on this project.
I will check out a CU for RCD protection when I get a chance
Reply to Flexishield cable in the UK Electrical Forum area at ElectriciansForums.net
I came across a UV steriliser tube with end caps like this while doing an EIC on a farm a few years ago. The damn thing actually bit me while I...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
