Discuss Flexishield Cable in the Electrical Tools and Products area at ElectriciansForums.net
It is a nightmare to strip. Did you find an easy way?Used thousands of metres of it at our current job. Stuffs a nightmare to strip at DB end as you have to do it in 6 inch bits. The cable is stiffer than FP and so dresses on tray niceley , but it has a tendency to kink easily aswell. Overall CSA is a bit bigger than FP aswell.
As for price , the ÂŁ100 for 100m of 2.5 is about right, but sure you could get a decent discount off that . We always buy from Cleveland Cable. Would never entertain the idea of burying it , would be like direct burial of FP.
Nick
Use it quite a bit, different manufacturers make a. Difference some drums of it are worse than others, sometimes it comes off in one or two pieces to do a db, other times(rarely) it’s probably 50 pieces, Doncaster cable multi use and flexshield normally strips ok, atom is hit and miss and cheaper/unknown stuff can be an absolute nightmare if you want to avoid damaging the cores.It is a nightmare to strip. Did you find an easy way?
Reply to Flexishield Cable in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
