AJ16
[h=2][/h]
I fitted 5 Click 50W 240V downlights and a Click 400W dimmer. The dimmer failed after short time. I just tried a 400W dimmer from Denmans but it flickers badly more so when on turned round to the fully on position. There is a normal 1 gang two way switch at one side of the room and the dimmer is the other side. When there is a normal switch each side everything is fine, it's just when a dimmer is fitted that the flickering starts. Is there an obvious reason for this to be happening?
Thanks AJ​
AJ16
flickering downlights only with dimmer
Australia
AJ16,
AJ16,
