Flickering LED downlights on 2g2w switch | Page 2 | on ElectriciansForums
Discuss Flickering LED downlights on 2g2w switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
An after thought as well. . If you've fitted an RC contact suppressor , what happens if you need to do a test and inspection.Will it be damaged or corrupt results
Its rated 250V AC ,so should be good for 500V DC All day long.
...Not snubbing contacts ,but driaing un used energy from lamps.....
( Would probably remove phantom voltages from some of circuit with no lamps fitted )
" Should it be mentioned in a notice on DB ?"
--That is a good question-- !
Reply to Flickering LED downlights on 2g2w switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
My hypothesis was the clamp of the relevant MCB being outside of the prong on the busbar, but the lack of a CU sinks that theory. Is this all...
Neutral and live
