Flickering supply | on ElectriciansForums
Discuss Flickering supply in the Australia area at ElectriciansForums.net
T
TinMan
Anybody out there who can help? My supply is flickering, lights as well as sockets, have tried isolating each circuit breaker but still flickers. I'm a photographer and need to get it sorted, the computers definitely don't like it as well? Suggestions would be great, or hands on help if that doesn't work, I'm based in Old St area in London.
Cheers
Nick
IF you are confident enough you could try tightening all the connections inside your fuseboard, i would recommend and electrician though
PS if you do, make sure its a insulated screwdriver !
poor connection on tails, can be in CU, meter, service head. if fluorescent lighting, could be low voltage. with as much equipment turned on as you can, listen for any crackling at the CU area. if so, an electrician needs to visit.
Sounds like a slack connection Turn the mains OFF and IF noone replies you could phone someone out BUT Not till the morning unless its desperate due to cost of call out charges
Reply to Flickering supply in the Australia area at ElectriciansForums.net
How did it go?
