Although prob easy question, I am installing my first heat mat and am wishing to make sure that the floor sensor is fitted right !
I have got some small tube that I'm pretty sure the sensor goes inside and protects it when it sits in chase in floor before self levelling goes down. But do you leave the sensor tip / bulb inside tube slightly rather than proud and then tape end sealed to stop any muck getting in ? Just wondered if the sensor will then pick up temp from inside the tubing ok ?
