Hi all,
Just wondered what method you find best for getting floorboards up ??
I tend to use a hammer and bolster, starting towards the end of the board i hammer the bolster down the side of it and lever it up, working my way along until it comes up completely, this does the job but i do tend to damage them from time to time. I did see a special floorboard crowbar advertised somewhere once and wondered if they are any good ??
Know what you mean there, but i've seen heating pipes that were close to the underside of the floorboard get knicked with the router cutter also.
I think whichever method you use, it all comes down to whos been there before and if the pipes or cable have been installed sensibly.
Myself circ saw and a board lifter.
Oh yes few weeks ago three of us working installing some additional smoke detectors in a house chip board floors 4 x 2 sheets , drilled a small hole 32 mm in the board poked the camera about every thing center of the joist pipes cables etc brill set the depth of the circular saw cut it out took the board out and underneath was a 22mm gas pipe missed it by a milimeter , home change of pants ,so be warned :eek:
How do people cut out the tongues in tongue and groove boards? I've used my multimaster before, but that takes a while, and used my bolster to bash it out but that can get a bit messy.
Also those big holesaws for solid board floors are good, but i hit a central heating pipe with one the other day! It was tight against the underside of the floor, and was the only pipe that hadn't been marked on top of the board. Straight through it with the pilot drill!!
Circular mate
Try and get a measure to the top of the tounge and add 10mm, set the saw to this and it should cut the tounge but not co as far as the underside of the board. as for cross cutting the board add another 5-10mm and cross everything!!!
Floorboard removal
Australia
Dazza1976,
High Tower,
