floroboardsaw ,jig saw or circular saw | Page 2 | on ElectriciansForums
Discuss floroboardsaw ,jig saw or circular saw in the Electrical Tools and Products area at ElectriciansForums.net
The JML saw looks great. Are we all the same, keeping power tool catalogues under the bed?.....
I had a go with the JML saw and didn't really like it. Good idea though as you get a really good cutting range. Just wish Bosch or someone would make something similar.
I currently use a Bosch 110v circular saw for when there are a lot of boards to lift, a Makita 14v cordless circular saw for the occasional use and a Fein multimaster (with depth stop) for when I need to keep mess right down.
I do the same as the other guys, usually lift a board the old fashioned way and then set the blade depth to avoid cutting pipes etc. Another good thing about using a circular is that you can make your end cut, do it at a 45 degree angle over the joist so when you put the board back it has something to support it.
Coincidently I still have the original blade in the Makita and have hit loads of nails will no ill effects yet!!
My Bosch is still the original too. I started a rewire earlier this year, my apprentice and myself were using bolsters and jimmys, but doing it as neat as we could, then the plumber came on board the next day and knocked 2 tons of carp out of em.
So I went straigt to the nearest shed to pick up a circular saw, no way was I being held responsible for the damage.
Plumber ended up knocking £600 off for the floor to be replaced.
Reply to floroboardsaw ,jig saw or circular saw in the Electrical Tools and Products area at ElectriciansForums.net
