fluctuating resistants reading megger met 1710 | on ElectriciansForums
Discuss fluctuating resistants reading megger met 1710 in the Electrical Tools and Products area at ElectriciansForums.net
billy
englan
Hello I'm getting fluctuating resistants readings when using a megger mft 1710 meter, Does anyone know whats causing this / how to mend it. Ive tried taking it apart to have a look inside but can't even take it apart does anyone know how too (ps its not the same as the older testers)
Well it depend on what you are testing or it may be the leads but I wouldn't think It would be something you can fix easily by having a look inside. There are screws under the batteries and I think under the label as well. I use Universal Instruments in Leicester for calibrating they are a good company for repairing test kit as well. Not sure were you are but I'm sure you can find some one local with experience in fixing your Megger. If not bin it and get a new one delivered next day, we are all on thousands of pounds don't you know and time is money!!
first try your leads in a mate's tester, if OK, then clean your 4mm ports in your megger. failing that, it could be a dry joint inside the megger, on the ports, or on the connections into the pcb.
I've tried different leads, also cleaned the ports, would check the pcb / joints but can't even get inside. its not like my old mft 1553 where you take the sicker off and undo the screws. I've never seen a case like it on anything
most things with a mft giving iffy readings can be down to one of 3 things, batteries, the leads/contacts or the fuse inside.
Not sure about meggers and whether you can access the fuse to check it is seated tightly. but with others that can help.
change your batteries, clean the leads and test against known values.
Also check how you null your leads out.
Try Zeroing the leads first, unless you do that the readings will not stabilise.
Done all of that, no point testing against known values because its not consistent. If I move the connectors it changes
westward 10 im seriously considering that lol. do you use separates? if so which ones, how do you find them vs a mft
My separates are a Robin loop tester and insulation tester and a Megger rcd tester, no problems whatsoever. Colleagues use mfts and they seem to spend all day faffing with them.
I had an amprobe mft and if I left it in the vehicle overnight the low ohms resistance readings went crazy. I assume it was condensation in the MFT. What degree of fluctuation is there 1 ohm to 200 ohm or 1 ohm to 20 ohm? You have no doubt ruled out the circuit you are testing and presumable get this on any circuit?
Reply to fluctuating resistants reading megger met 1710 in the Electrical Tools and Products area at ElectriciansForums.net
Hi Richard Thanks for the reply, it won’t function as it will with the MFT1741+ but will I be able to use the MFT 1721 and perform all the...
That is very cool. It would be the end user software that would make that the absolute king.
    • Winner
    • Informative
