Fluke 1663 multifunction tester error code 4 | on ElectriciansForums
Discuss Fluke 1663 multifunction tester error code 4 in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
dnjr
South coast
Dear all
Testing Zs on fluke 1663 returned an error code 4
I thought this was an earth fault but another spark said it’s a voltage on the line.
Anyone have the correct answer
Cheers
I have had that when there has been a lot of electrical noise on the line, try later when everything is turned off
mate had same with his fluke....noise. got my trusted 1553 out and it read the Zs perfectly.
Reply to Fluke 1663 multifunction tester error code 4 in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
Hi all, The electrical network in my house (Antwerp, BE) is quite old and consists of two phases of about 140 volts. This gives me approximately...
