Fluke T110 fail self test | Page 2 | on ElectriciansForums
Discuss Fluke T110 fail self test in the Electrical Tools and Products area at ElectriciansForums.net
yep. Its probably out of warranty anyway. It looks like I purchased it last april. Its hardly been used really.
I checked with a multi meter and there is no continuity between the 2 probes
Well that's naff. When buying a reputable tester from the likes of fluke you expect it to out last you. :(
get it opened up; check soldered connections of the leads inside, and the continuity of each lead, tip to PCB.
Reply to Fluke T110 fail self test in the Electrical Tools and Products area at ElectriciansForums.net
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
I just had a look, and the Klein and the Southwire are both "True RMS" meters, whereas it appears the Fluke is not, as it says "averaging" against...
