I normally bash through these worksheets quite quickly (or at least, I rarely get one like this which I just can't suss out), but this one has got me stumped.
Yes, I've googled it and youtubed it for a while (although usually I only really resort to that when I don't have the knowledge to work it out myself, or when logical deduction can't crack it) but I can't find anything which addresses this exact situation.
So I know that 1/Rt = 1/R1 + 1/R2 + 1/R3, and then you'd need to convert 1/Rt into a decimal to get your answer. but I don't know how to do the reverse operation, with the limited information provided here.
So there's no values for the voltage or current (which I guess you could 'make them up' in an attempt to use ohms law as a roundabout way of getting the answer, but I'm sure that's not the way we're supposed to approach this question, or even whether that would necessarily work).
Maybe I've missed something really obvious, and if so I risk looking like a plum here, but whatever, if I learn from it then it was worth it.
I have a suspicion that it would be possible to transpose a formula to work it out, but I'm not sure how to formulate the formula. I guess one such formula might be 1/R3 = 15Ohms - (1/48 + 1/80), but then that's not right, I dont think so anyway, cause the 15 ohms needs to be converted back into 1/something. That's where I'm stuck.
1/48 and 1/80 are not difficult to calculate, but I don't see how that helps. Basically, it seems that the problem needs to be addressed from the other end, i.e. I need to know what to do to the 15 ohms to make it equal 1/something. From trial and error I find that 1/0.065 = 15.3846, but in an exam (or eventually on a job) I can't waste time on trial and error, which anyway would only reach an approximate answer. Real life won't have multiple answers from which I can choose the closest one eh.
So basically, could someone kindly advise me as to the best/simplest way to convert 15 into 1/something.
Cheers
