fluorescent trouble | on ElectriciansForums
Discuss fluorescent trouble in the Australia area at ElectriciansForums.net
davelerave
i fitted 4 5'twin corrosion proof T8 with electronic ballast
3 of them are giving trouble -sometimes they start
other times not -or might go off after a few minutes
i assume there's a fault with ballast-i doubt it's voltage but will check
anyone had similar issues thanks
Reply to fluorescent trouble in the Australia area at ElectriciansForums.net
It should give fairly accurate results. Bear in mind your car will probably have a smart charging system, so worth having a read up on those.
I've discussed this with the OP directly as we are friends, but for anyone searching in the future, the service manual suggests that this...
