Flush mounted pull cord backbox and theories | Page 2 | on ElectriciansForums
Discuss Flush mounted pull cord backbox and theories in the UK Electrical Forum area at ElectriciansForums.net
Market harborough
Hi all,
It just popped into my head about bathroom pull cord switches, do they ever have flush mounting boxes, every one I have seen has been surface mounted, and also, why are shower pull cords cut shorter, which I see in most places?
A properly installed good quality dry lining box on a 12.5mm Plasterboard Ceiling is fine in my opinion. The cord would be snapped long before any damage could be done to the ceiling
unless you got one them .
[ElectriciansForums.net] Flush mounted pull cord backbox and theories
I can't see the point in making a shower pull switch flush really, it is what it is.
why not mount in attic on some scrap wood left over by builders, say 4" above ceiling, then a 1/8" hole in ceiling for the string. totally discreet switch.
Most houses here are from 350-450 spacings, can't recall ever seeing 600. Then you also have the wall about 10-15mm away for more support...unless it's gonna be installed in the middle of the bathroom, which I can't say I've ever come across.
You are also kind of putting a lot of faith,in the board fixings,which unlike the spacing of rafters,cannot be known.
I have seen lads drop a piece of 10mm ply,between the rafters,and Instastik it,in position,with a foam adhesive gun,the hole can be cut after a short while,with a padsaw,and made a solid job.
I think Tel's idea,was a good one,and i can only improve on it,by suggesting,fitting a pull switch under the floorboards,with the string exiting through a tiny hole...then put a helium balloon on the end :)
...In fact...it's how i will do it,from now on...
Reply to Flush mounted pull cord backbox and theories in the UK Electrical Forum area at ElectriciansForums.net
Better off with the click prw213 as it has twin screw termination.
Obviously not a building/DIY forum so will keep it short but yes - we've taken all the floors up. Several joists in the bathroom need doing as...
