Foot bender, Wire Strainer | on ElectriciansForums
Discuss Foot bender, Wire Strainer in the Electrical Tools and Products area at ElectriciansForums.net
P
philosopheer
Two things I had not been able to get when I started on my own- doing a bit on farms I could have done with a cable strainer for overhead supplies to buildings; also a footbender for conduit, which is much quicker to use than one on a stand.
A girl from a tool firm called to say they could not find them and was I pulling her leg asking for a bender and a wire puller.:)
Foot benders are the greatest tool ever invented,
Mine is by Greenlee and I brought it back from the US. Its called a 3/4inch EMT bender over there. As for the wire strainer, sorry can't help you there.
Bazza2541 how did u adapt from three quarter to 20mm. Was a former readily available?
I have a 20mm and 25mm version, but cant remember the name, i'll look later and post another reply, i thought that all wholesalers had them, maybe they've gone out of fashion as i've had mine quite a while.
Yes, thats one. The greenlee one I use came with a shaft fitted which had all the fractions printed on it.
Easy and quick to use, makes complicated bends a doddle.
Gets my vote for second bestest tool ever.
Yes, Mark Sparks, this is the foot bender! You may have seen a plumber use one for copper pipe; why should they have all mthe fun. You can be some distance away from your vice/bender on a big job and you can have your conduit bent by the time it would have taken to walk to the vice or stand bender.
They have been around for quite a while . I first used one in 1990. The gulf war had just started.
I am from a generation when houses used to be done in BE steel and we usually bent it with our knee. No wonder I've got bad knees now.
I've also got a bad shoulder from carrying bundles of conduit, ladders, toolboxes and all sorts on my shoulder.
I digress. The foot bender is the greatest thing since sliced bread, you can even ues it in a roofspace.
Simples(squeak).
Reply to Foot bender, Wire Strainer in the Electrical Tools and Products area at ElectriciansForums.net
"It works" and "it's safe" are not necessarily the same thing. With DIY work, they are often far from the same thing.
You should have no problems with what you want but even if you install conduit the cable still needs to be UF cable which is approved for under...
