Pete999
BT Tool kits where ace those little zipped up hearing age beige bags.
Not sure which one you are talking about...
As an apprentice, you were issued a small leather wallet not much bigger than a pencil case to hold three screwdrivers, cutters, wire strippers and 81's (long nose pliers)...
Later you were issued the larger leather No3 wallet which was actually a very useful size..
The photo above includes the small hand auger, but I recall a larger one which had a metal eye instead of a tee handle and was turned using a screw driver as a lever...
I still have a No3 wallet somewhere, I shall have to dig it out...
Ahhhh yes the number 3 I had one somewhere then you had the larger one as well, I remember the yellow handled screwdrivers and have one somewhere I believe, I think I gave my bag away in the end, still have my Krone tool. Not great for CAT6 cable terminations though.
Number 6 NICE OLD BT leather tool bag NUMBER 6 P.I.C.1987 | eBay - https://www.ebay.co.uk/itm/NICE-OLD-BT-leather-tool-bag-NUMBER-6-P-I-C-1987-/382329853127
Still have a few of the yellow handled screw drivers knocking about as well! lol I have seen a set of the old wooden step ladders going for a stupid amount on ebay after they were tagged as "vintage" lol
Once spent two whole weeks doing nothing but drilling holes, with the rawldrill and hammer, into concrete in an underground pumping station. I think I only broke two drills. Hell of a job to get out of the hole when you did. Pyro job that one.
You guys ever come across Ruabon Red engineering bricks? You could scratch a diamond with one...A lot of the council houses around this part of North Wales were built using them, including tiled skirtings of the same stuff. Even the mortar courses were like cement...getting cleats in was a nightmare as was drilling even when the elecy hammer drills came out...
Yes, used to use the brace & Rawlplug chisel & the buckle clips & the bolster chisel knocking the feather off floorboards.Took ages and the ears got a right bashing.
That's a carpenter's brace. Electricians brace was much smaller with a short crank that you could turn between the joists without taking off your knuckles on the lath and plaster.
Those yellow handled screwdrivers used to make your tongue go numb if you held them in your mouth whilst working - I think they were made of cocaine!
Pete999
Northampton
United Kingdom
Retired Electrician
Business Name
None
For old time House Bashers only
Pete999,
telectrix,
