Hi,
Long term guest viewer but could do with some advice if that's ok.
As above, 55 plate fiesta 1.4 Style that wont crank.
Immobiliser flashing red led doesnt phase out after ignition turned on. Flash Code 16 (CAN link error between PCM and Instrument Cluster).
Battery is 13v.
Fuses checked behind glove box ( could not see any under the bonnet).
Battery terminals removed and left for a few hours and also cleaned up the ground to the negative terminal from a thick loom nearby.
Removed steering column cover and checked PAT ring around ignition barrel all looks good.
Decided to hook up two different OBD2 readers, but had linking error so tried my laptop with a ELM but software stating 'cannot detect power please check ignition is on' (which it is).
Bit stumped as to the next plan of attack?
Regards
Battery is 13v.
Regards
