Just been watching a jointing video, (yes I know how sad) the Jointer (a Russian) was building up a lead solder finish to the Joint, can't recall what the correct term is for this sort of skill, can anyone put me out of my misery?
Discuss Forgotten something. in the UK Electrical Forum area at ElectriciansForums.net
Seeing as you can't means you are still on the amoeba scale..... I love you too Merry Christmas and a Happy New Year ;o)))))))I am still trying to guess SWD's level.
Which post are you referring to?I see my last post has been changed to not offend certain mod. At least have the decency to pm me that you have changed it for your own agenda
If that’s true, whoever did that wants binning from the team.I see my last post has been changed to not offend certain mod. At least have the decency to pm me that you have changed it for your own agenda
You know which oneWhich post are you referring to?
You know which one
they here. easy for him to look at.PM admin or even Dan and ask them to look at the logs.
Yes of right course, I was mixing copper pipe jointing, not cable jointing, should have realised my error.I think you're thinking of wiping a joint, where solder is applied to the work, built up to a thick layer that is then shaped while it is semi-fluid. E.g. you wipe a joint between the sheath of PILC and a brass jointing cone. A.k.a plumbing the joint.
Swaging is a cold process of hammering / forging / pressing a part using a die / swage / mandrel to change its shape.
corrected that for you.You solder a connection, sweat a load ((Okay, don't shudder, that was then) and wipe your arse
Reply to Forgotten something. in the UK Electrical Forum area at ElectriciansForums.net
