Found this today | on ElectriciansForums
Discuss Found this today in the Australia area at ElectriciansForums.net
Swansea, South Wales
Went to a job today to check the electrics for a customer as he is going to rent it out.It is currently not occupied thankfully. Went to look at the supply and found this(attached pictures).I have phoned western power and they are going to sort it. Left the fusebox off with no fuses and warning notice attached.Anyone seen this shocking before no main fuse?
  • [ElectriciansForums.net] Found this today
It looks as though the one on the left is a rewirable fuse presumably phase? and the one on the right is not fused (neutral) although when it was installed it was common practice to fuse the live and neutral. I wonder it it had another supply looped off it at some point? New cutout and it will be fine.
yer, the one on the left is phase. thanks mate western power wont charge the customer for this it should be free aint it? The supply is TNS. the clamp is not the correct SWET type just a bonding clamp. They should upgrade this too when the come?
Reply to Found this today in the Australia area at ElectriciansForums.net
Well yes obviously, but if the transformer is indoors and your lights are 50m down the garden then it's very easy to need pretty big cables at...
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
