View the thread, titled "Free download nvq 3 portfolio + c&g 2356 stuff" which is posted in Electrician Courses : Electrical Quals on Electricians Forums.
Damon
Hi guys I am new on here but i got hold of some information I would like to share.
Its a bunch of NVQ Level 3 Portfolio and c&g2356 portfolio information.
Feel free to download the stuff you have to pay a fiver for on ebay.
Free Download NVQ 3 Porfolio for Electrician Trainees Currently on Electrical Courses. Download expired, Link removed. Register to the forum and view the resources section to see the current available files and downloads. :)
And please only use it as a guide not word for word lol ;-)
PS: This is my webspace not a third party download site-all files are in zip format
Edit: these have been moved to a private forum for members, access the training area and join in and you will be helped.
hi lads just noticed the post I do have a digital form of the proper candidate pack for the nvq3 please pm me with your email address if you want it thanks...I must point out this pack is blank and for your own use to build your portfolio
[email protected]
read first and work out how you are going to install it simples .
Cheers Buzz, I'll check that out.
Not necessarily. See below.
You need to check whether it is looped supply. If so, stop, and apply to connect.
You need to know existing max demand. If the house routinely pulls more than 60 amps (and it has an 80 or 100 amp service fuse) then stop, and apply to connect..
Otherwise you can crack on and install a charger that will throttle the charger if the grid limit exceeds 60 amps, and then tell the DNO you've done it.
Choosing a charge point that has built in double pole RCD protection including 6ma DC leakage protection makes this simple as at the CU it can just be an MCB in an existing consumer unit and armoured cable (so impact protection rules are met).
You'll need a CT clamp around the meter tails, so will need data cable to the charger too, or use one of the products such as EV ultra that has data within it.
Assuming it's TNCS earthing, you basically have a choice between isolating the earth at the charger and sticking an earth rod in, or connecting the CPC as usual and using a charger with PEN fault protection.
A PEN fault is when the combined Neutral and Earth supply conductor get's broken. This can create a very dangerous condition where all metalwork becomes live, and a person completes the circuit to earth. It's generally not so serious inside a house (vast simplification) but as cars live outside, it would obviously be pretty lethal to have a car body at a potential of 230v. Hence the PEN fault protection issue.
I've not done many of them myself but believe the above summarises most of the pertinent points.
Cheers Tim, thanks for the info, very clear thank you.
Upvote 0
You won't get them on here pal!
You mixing this forum that supports and is supported by training industry and electricians not cheating and risking screwing up thousands of other people's properly for personal financial gain.
...with another less top notch forum?
Upvote 0
Are people really expecting someone to hand over their hard work??
Am I missing something?
Upvote 0
It appears somebody was. We'll keep the thread up to bring trainees to the forum, then they can get in the training access only forum and get the help they need.
I've closed this thread for now.
Upvote 0
Reply to the thread, titled "Free download nvq 3 portfolio + c&g 2356 stuff" which is posted in Electrician Courses : Electrical Quals on Electricians Forums.
Electrical Courses
