Agreed- a) we are dealing with a different set of regulations and b) whilst the OP may be a very capable chap, the fact that the answer to this question was not abundantly clear when first setting eyes on the illustration, suggests not enough experience to safely tackle a CU installation.
Re upgrading to SP+N, the supply may previously have been a small TP+N service, which was once common on the continent, where the total capacity was adequate but no one phase could carry any large loads so cookers etc all needed to be three-phase too, which made things complicated and limited diversity,
Looks like different methods of connecting the supply to the CU utilizing different styles of bus bars,
If you follow the wires the brown wire goes to the brown bus bar and the blue wire to the blue bus bar
Pierre this is your big chance. Go out and sort it for him and then fill the boot up with Vin Rouge.
So what is the answer ?
Hi yes the farmhouse was supplied by triphase which it needed for milking machines and well pumps and stuff. Had EDF to change the supply over to monophase which is all i need for a small domestic installation (we have 6 large rooms/bathroom including a 37sq m kitchen but we're only having 12 double sockets, 12 lights, a water heater and electric oven/extractor fan. We may in the future put some electric rads in to complement the wood burners but we'll see how we go.
I know it's a different set of regs and appreciate all the help and insight on here but regs aside, i was just after the electrical theory of wiring L+N to N+L.
Seems from the two guys above though that it may be an illustration fault as it's the only picture i've ever seen in a book that looks like this and if it is an illustration fault (and nobody is pulling my leg) then the publishers should probably be notified of it because it's aimed at DIY'ers, written by qualified French professionals and someone who didn't notice the discrepancy could do it wrong. Again, i don't know if this would be dangerous because everybody seems apprehensive to actually say what they think about it for some reason, but it would be good to point it out to the authors at least !
Yes i was in the equivalent of B&Q yesterday and they didn't have any single pole trips.
You will not get single pole trips in france, their regs are for duel pole. I lived and worked in France for 12 years so know my way around their regs. If you PM me i will help you out where i can.
Victor
Et voilà. On, working, certified as safe.
How's that for not being able to follow a schematic drawn up by an electrician ?
Hope you wash-ups can find the money to do the next nonsense pointless upgrade to the regs.
Get some.
Victor
Thanks mate but i've finished the job now. Just have to wire up my balon and then wire that up to the heures creuses switch and we're ready to rock.
Sorry Pete this is the same half wit that posted a thread the other day about earthing a rod with a bigger sized cable then throwing a load of abuse and Lee closed it. I have reported it but it still seems to be running.
French wiring book showing Type AC 40a breaker with N and L wired opposite
pipunch,
GMES,
TrueNAS JBOD Storage Server
