Hi,
I have been having issues with our fridge causing my modem and video card on my pc to drop out.
-They are on the same ring circuit, have been for years with zero problems. The problem has been happening the last few weeks when the fridge compressor cuts out, It might blink a little on startup.
-Our fridge is only 160w but obviously motors can spike the current on startup
-I have checked all the sockets on the ring to ensure the ring continuity.
-Checked the plugs and fuses not loose
-Our CU has an SPD ( still green) protecting the supply.
Fixing Fridge, is this likely the starter capacitor causing problems or thermostat?
Will a surge protector on the fridge plug , pc plug or both help?
Any other advice welcome
