Fridge Thermostat help, please | on ElectriciansForums
Discuss Fridge Thermostat help, please in the Electrical Appliances Forum area at ElectriciansForums.net
botty67
Ireland
Hi,
I was replacing the thermostat on my hoover/candy fridge freezer. I took a picture but it didn't save and now I can't find anywhere that tells me where the correct wires go.
Can someone help or tell me how to diagnose it myself? The fridge freezer is an integrated Hoover HBCP3150/1KD. The thermostat is wdf25t-100-027. The wires is black, brown, white and earth.
The only thing I know is that these wires don't seem to follow normal fridge wiring colours.
Can someone please help.
Thanks in advance.
To wire your Hoover HBCP3150/1KD fridge freezer thermostat (wdf25t-100-027):
  1. Safety: Unplug the appliance.
  2. Wiring:
    • Earth (Green/Yellow): Connect to the thermostat's metal body.
    • Live (Black and Brown): Connect to the "L" and other live terminals.
    • Neutral (White): Connect to the "N" terminal.
  3. Check: Use a multimeter to verify connections.
If unsure, consult the manual or contact a professional for guidance.
Thanks so much for replying to my question first of all. The thermostat has the below markings. C H and L.
Sorry, multimeters worry me when dealing with 220v. Am I fine as long as I select 200v?
Thanks again
  • [ElectriciansForums.net] Fridge Thermostat help, please
Ignore the post in #3 it is of no help. Hopefully someone may know but it maybe a longshot, have you asked on a more specific appliances forum?
Reply to Fridge Thermostat help, please in the Electrical Appliances Forum area at ElectriciansForums.net
I have a Hoover HBCP3150, integrated fridge freezer. Probably 3 years old. It's immaculately clean inside and out. It looks brand new but the...
If properly designed as "frost free" then it won't. As i described above, such freezers typically have a finned heat exchanger (HE) with a fan...
It is worth noting that many of the devices you have purchased in the states will be destroyed if you plug them in to the mains in israel. you...
It all works now. Thank you so much.
Goodmorning guys does any of you have a wiring diagram for a bosch fridge KGN56VI30U. Please it is urgent if you can help me. The display comes on...
