fronius ig 30 wont start | on ElectriciansForums
Discuss fronius ig 30 wont start in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
P
Phantasmagoric
any body got any experiance with fronius inverters just installed a 2.6kw pv system and inverter wont do anything iv tested power on both sides and its fine any one got any advise
You need to give more detail. What size array. How many strings? Was there any light when you connected it. They wont start if there isn't.
The system is a 14 panel 190w I did 2 rows of 7 in series 1st then changed it to 10 in series after some advise from someone Just to check inverter. The inverter is an ig30 it doesn't have a dc switch
It says "No ideal configuration possible". The suggestions it gives is an additional panel. 3 stings of 5 = 2852w or 4 x 4 = 3042w
Reply to fronius ig 30 wont start in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
hello team, One year ago, I installed a solar PV system with batteries in my house. Whenever i start large loads, the inverter doesn't support...
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
