Fronius Transformerless Inverter | on ElectriciansForums
Discuss Fronius Transformerless Inverter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi there
Any help most appreciated
According to the operational manual for the fronius IG TL 3.6 it has an RCMU to protect against residual DC currents. so a B type RCD is not required, It then goes on to say if an external RCD is required due to local regulations then a type B 100mA RCD should be fitted.. Does this mean if it is a TT installation it must have a seperate type B RCD????
Any suggestions where to get one? I've spoken to a couple of my local wholesalers and lets just say they aren't equipped to deal with my request...
If Fronius state a type B is not required 'cos the inverter has an inbuilt RCMU to deal with DC residuals, why would it need a type B for a TT installation? Surely it either needs a type B for all eventualities or it doesn't.
I've read it as being because TT installations require all circuits to be RCBO/RCD protected, so the connection to the grid is via a RCD making this an external RCD. I may be wrong though..
It will require an RCD for a TT installation to meet disconnection times. My question is why a type B? If the inverter is incapable of feeding DC faults onto the AC side due to its construction, as it would appear to be, then a standard RCD should suffice (see last line of 712.411.3.2.1.2). If the inverter can feed DC onto the AC side in the event of a fault, then a type B RCD should be fitted at all times, not just on a TT installation. Seems contrary to what Fronius state.
Many thanks JC seems straight forward when you put it like that, So in that case I can use a standard Type AC RCD I don't even need to use a type A RCD?
I dunno! I'd say yes, a standard type AC would do, but it seems Fronius say not. In which case, go with the manufacturer's recommendation on the basis that they know a lot more than I do. I am just curious as to why they recommend a type B if they also state that their inverter can't feed DC onto the AC side.
Where is the spiel from fronius about this? I couldn't find it online? I was looking for this myself, as I nearly ended up with a fronius TL on a job..
Reply to Fronius Transformerless Inverter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Protection from what? What kind of problem with the inverter is going to be helped by having an RCD on the circuit?
davesparks
