Evening all,
Have been asked to wire one of these into a heating system that has no separate control (or valves) for HW & CH. Customer is going to be away and wants it wiring in to allow the heating to only come on when the temp drops to keep pipes etc from freezing.
However I just want to make sure I have this right as not wired one in before.
I am assuming I just connect this to the perm L & N and call for heat in the control centre? If he switches the heating off at the usual timer control panel, will this still kick in and turn the heating on once the temp drops below the set value? The instructions just say L, N and terminal 3 call for heat.
Carl
Carl
