View the thread, titled "Fuel Gauge needle moving with revs issue" which is posted in Auto Electrician Forum on Electricians Forums.
The scooter wasn't fitted with a battery and is 12V AC, but the one the gauge came from was 12V DC. I added a diode to this gauge to make it work with AC.
Another gauge was tested on this scooter with the same results.
Not sure what you mean by putting the meter on the AC range. You mean plugging the red wire on the left? I've been conducting all these tests plugged to the right.
I just tried on the left, and the readings are usually 0
If the gauge isn't intended for DC operation then that is probably your problem.
Don't use the left hand socket, that is for current only, and will effectively short circuit anything you connect between it and the centre socket.
The gauge IS intended for DC operation, which is why I added the diode. The setup is similar to another gauge tried, for use on an AC scooter. Same needle wavering.
Sorry, I'm out of ideas.
Hi! I've been having issues with the fuel gauge on an old vespa scooter, and I'd like to ask those who understand these things for advice on what I did wrong, and/or how to fix it.
The scooter is 12V AC. The stator produces (on paper) 120w, which is passed through a 3-pole regulator (12V; 20A), and goes to the gauge according to the schematic below. The float unit is brand new, and has been tested.
The diode is a 1N4007, and the resistor after it is a 5.2 ohm unit.
The issue is that, starting the engine, the needle goes to the correct position on the gauge (the tank was full for the video), and generally gives the correct reading while at idle. However, whenever the revs go above idle, the needle moves to the left. I have this same issue with a spare gauge, so I'm inclined to think this particular gauge isn't at fault, but the way the circuit is set up.
Here's a vid showing how the gauge reacts when revving the engine:
Any idea what may be causing this? BTW, the regulator is NOS, and although I haven't checked its output, it seems to be working fine (no blown light bulbs).
Is there no voltage stabiliser fitted ?
Usually the stabiliser gives a regulated 10 volts supplying the gauges.
Did not answer the question if there is an earth strap to the engine and while we are at it, is there a suppressor on the spark plug?
Turn the meter selector switch 2 clicks to the right where it shows 200 V, this will measure AC , depending on the meter it should give an accurate reading then connect to the lamp as you were doing it before and note the reading. As you have a DC gauge you need a better rectifier and a voltage regulator but you do need a good idea of the voltage range in AC before a suitable regulator will work across idle and full revs.
just one diode will not cut it as you have a frequency change with revs which changes the voltage in DC as presented to the gauge.
Isn't an earth strap for battery-equipped vehicles? In any case, no, there's isn't one on these scooters. Just a ground from the stator plate to the body, and another ground from the cdi to the engine.
No suppressor on the spark plug either.
OK, now I get it! :D I'll check that tomorrow and report back.
So apparently using the right setting on the voltmeter helps a lot :D
Also, looks like the regulator is in fact fine.
I let the scooter idle a little longer before the video, and the output was consistently around 10V at idle. There are a couple more revs available above what was attained here, but in regular traffic this would be the rev range (giving in the realm of the 12-12.9V mark). Btw, the needle was nearing empty at those "high" revs already.
Check the dc voltage at the rectifier.
Has there been any alterations to the wiring etc.
Is there room to have a battery ?
There is no rectifier, and no flasher relay either (no turn signals). I posted the diagram to show that the current wasn't transformed on its way to the gauge. The rectifier was fitted to some models for the horn for some markets, but not on mine.
The only alterations to the wiring were to add a brake switch to the handlebar in line with the foot pedal brake switch; also, the brake pedal is fed through the main circuit instead of having its own wiring, and the rear light has its own wire coming from the regulator. Nothing that interferes with the gauge circuit as far as I can tell.
A battery could always be fitted, but the point of this bike being all AC is to keep it simple and easy to repair and maintain. I'd rather avoid that route.
Reply to the thread, titled "Fuel Gauge needle moving with revs issue" which is posted in Auto Electrician Forum on Electricians Forums.
France
France
Thread Tags
Tarlow,
Tarlow,
