Full Meter kit, what's best | Page 2 | on ElectriciansForums
Discuss Full Meter kit, what's best in the Electrical Tools and Products area at ElectriciansForums.net
Unless it has changed (I complained to a Megger sales person at an Elex show), you must register the software within 90 days of purchase, to receive 30 days of tech support. The software is not the easiest to understand, you can purchase additional support on a yearly contract.............£179+vat! You could get a local rep to pop and see you for an hour, or go on one day training session......£300+vat! You can see what I mean. The completed certificate doesn't look that great IMO.
One of the reasons I bought the 1730, was the blue tooth ability, but you have to use it with their software. However, the rechargeable ability is worth it IMO. I haven't used the earth electrode test kit yet. I think Megger also offer a three year warranty. You can purchase just a 1730 without the software, Test Meter sell that for £954 (pick the earth wander lead as the free gift, cos you gonna need one of them).
PS Bought a few items from Test Meter, always received a good service.
PPS If you are going to do mainly Domestic, you maybe thinking of registering with a scheme, some of them offer (chargeable) online certification. I believe there are some free certificate downloads out there, or buy some certificate packs, and use an old fashsion pen & paper
Thanks mate, this is very helpful. I can see software getting very expensive.
You are correct, I'm looking at registering now. I like the idea of online certification so will also look into this.
Yep, some say it's just another example of profit generation by the schemes. However, I include the cost of the cert in my quotations, and the scheme takes on the responsibility of storage of it. With the Megger certificate, you need the software to open the certificate, hence I had to post all my certs to customers.
Whatever you do, don't trust the forum sponsor 'test meter' or whatever they call themselves, the customer service is non existant. I've waited a month for an order to arrive, they are waiting for one item out of three to come on to stock and they didn't bother to say anything until I emailed them about it after waiting two weeks. They sent a brief email reply and still no idea of when my order will arrive!
dont bother emailing them, call them.
there an electrical wholesaler as well so they will be busy
Seem to have a good reputation on this forum, I've had good service from them. Perhaps you should start a separate thread and see what response you get from them then?
I couldn't give a monkeys how busy they are, they should be contacting me to advise me that my order is going to be delayed by a month.
It's disgustingly poor customer service
true but that is the same with most companies now.
very few actually have helpful customer services, did you tell them you needed it urgently or to let you know if it was going to be delayed?
i know when i bought something on ebay i got a call that the item wasn't in stock and can either get a refund or wait a couple days
Hi gayowl I've just been issued a 1730 but didn't inherit its leads. With you saying the leads are cack are there any other leads that will suit this model or will I have to just order meggers?
Hi, Midwest said that Kewtech leads should fit earlier in this post. Not sure myself what would fit but they are 4mm banana type which is fairly standard I think. The Megger ones are not completely terrible, they are a bit annoying when you are changing between the clips and probes a lot. And the leads have stupid ridges that prevent you using a plug in test socket for your r1r2/r1rn tests. Though it is better to do r1r2 etc from the terminals really.
I would buy the megger ones again now I have got used to them.
I put brand new croc clips on brand new leads and then tape them on so that they never get removed. I then use a different set of leads for when I simply want probe tips.
By doing that, the croc clips leads will stay accurate for far longer, because you don't wear them out by changing the ends continually.
i reaply like the extech leads.
there 1.6m long which is very handy especially for a dmm
(double molded silicon leads, im using kewtech aligator clips with them)
Hi davesparks,
Sorry to hear that you are less than satisfied with the service received from us which is understandable if you have been waiting for a month for goods to arrive. We always endeavour to contact customers if an order has been placed that cannot be delivered in less than 3-4 working days so it seems strange that you have not bee contacted at the time of the order.
We are just trying to locate the order on our system so we can at least formulate a reply so your posts.
Can you confirm that the goods you are waiting for are:
TM-EL9809 Earth Leakage Clamp Meter
Megger AVO410 Multimeter
Extech CT40 Cable Identifier / Tester Kit
Best regards,
test-meter
Hi davesparks,
Best regards,
test-meter
...Service on orders,aside,that AVO410 multimeter is cracking,and has solved many a quandary for me. I got a pair of crock clips to add in the zip bag,and have been pleased i picked one with capacitance measurement,mixed in with the standard ranges.
Only this afternoon,i used it to identify a rare faulty ignition coil,on a Honda GX160 powered pressure washer,and it stays in the 4WD ,permanently.:goofy:
The Megger leads are a bit fiddly to pull apart to swap crocodile to probe ends. If you use a r1+r2 socket adaptor, you have to reverse the leads around to fit into the adaptor. On the recommendation on this forum, I got the Kewtech leads (think it's the ACC065, check with Test Meter). Much easier to swap the crocs/probes, & can be used with the Kewtech socket adaptor.
the kewtech leads are good, i use the croc clips on other test leads and they work fine (i get a better resistance using extech 1.6m leads and fluke tips than the fluke leads) on a dmm so cant null the leads
Reply to Full Meter kit, what's best in the Electrical Tools and Products area at ElectriciansForums.net
