Hi all,
Probably going to seem like a novice question just wondering what techniques you lot have for full rcbo boards to keep it neat.
Put 5 in today for a temporary supply for ground workers on a genny; earth rod with a Zs of 2.13ohms (fairly good?)
Anyway it was a complete nightmare trying to keep it neat with the earth and neutral flexes out of them.
I've only installed less than 10 just wondering all your techniques for rcbos?
I kept all the length on these and tried to coil them nicely behind the cpc and neutral terminals.
Yes 1mm can be crushed quite easily, and there is an improvement to be made there too. I'm not aware of any simple fix for this other than paying a bit more attention to the correct tightening of the terminal screw.
Describing situations where this problem occurs but it cannot be fixed by ferrules doesn't in any way support the idea that ferrules are unnecessary, it just looks like pointless mud slinging.
I would suggest that the use of ferrules, depends on how frequently you would use them.
Someone who does the odd board with one or two RCBOs may not see the need, especially as compliance is easily achieved by the method I posted earlier.
Someone who builds lots of panels however may find the use of ferrules makes their work easier.
What makes me chuckle, is when people ask if your ferrule crimper is calibrated.
Does anyone have any links to their fav ferrule crimping tool?
For the sake of a couple of quid for a big bag of ferrules I can't see any argument against it.
Someone who builds panels will be working to a standard which requires their use.
Dave I respect your views and can see you have alot of knowledge but I very much doubt you can even work to the standards you preach. Regulations are worded in such a way which leaves the overall decision with the installer and I have to agree with spin London on this one.
UK
Full rcbo boards????
D00DY_T00DY,
Davisonp,
