fuse box for generator | on ElectriciansForums
Discuss fuse box for generator in the UK Electrical Forum area at ElectriciansForums.net
linzibee
ol69hd
Hi good afternoon, this is my first thread on the forum so Hi everyone ;) good to meet you,
my question is I have a well which uses a water pump and I have a 9000kw generator which powers it could you advise me what kind of fuse box do I need to buy in order to be able to connect everything up to it to make it work, if anyone could advise me thanks so much , Linzi
Is this a temporary setup or a permanent installation?
Is it being operated as a TNS or an IT system?
Does the generator incorporate any protective devices and what is the nature of the output connections?
9000 kw, a rather large Genny is that R U sure about that?
No, you really need someone who understands the use and installation of generators. Someone involved will also need to to understand a load of other regulations if you intend using this water for drinking and even if you don't intend using it for that the simple act of abstracting water could lead to trouble. Just because you have a well doesn't mean you are entitled to PUMP water out of it.
Reply to fuse box for generator in the UK Electrical Forum area at ElectriciansForums.net
The last couple of de-loops that I have been involved with had the single phase supply replaced with a three phase cutout (as I believe the DNOs...
Yeah it's working thanks! Now there's a "halo" feature that is supposed to stay on even when the fog lights are switched off. Would you know how i...
