Fuse puller in older consumer box | on ElectriciansForums
Discuss Fuse puller in older consumer box in the Electrical Tools and Products area at ElectriciansForums.net
if you mean rewireable fuses, then no. but you should consider upgrading the fusebox to a modern MCB and RCD protected unit.
This is what I am talking about tool to pull carriers out
[ElectriciansForums.net] Fuse puller in older consumer box
pointless having fuses in that, it's not connected to anything.unless it's a new-fangled wireless jobby.
The only tools you need are your hands, using anything else will likely lead to breaking the carrier.
Sometimes they do get a bit stuck if they’ve been in place for a long time, but a bit of up and down wiggling should shift them.
Just remember to pay attention to the label on the cover (which is missing from your pic) and turn the main switch off before pulling a fuse.
Reply to Fuse puller in older consumer box in the Electrical Tools and Products area at ElectriciansForums.net
There's a difference between being required to install an RCD and being required to have a full rewire when all the houses around have similar...
Yes that does appear to be the case. I may get an electrician to fit the correct glands. Thank you.
