Well they would only need to pull them out once then! I had some recently that were cracked and some numpty had superglued them into the board.. thankfully it was being changed for a nice shiny new one.Because they cant get them out
Discuss Fuse puller in older consumer box in the Electrical Tools and Products area at ElectriciansForums.net
Still no RCD protection *cough cough*Why not get some mcb type replacements for it, saves changing the whole board and just flick a switch
You need a heavier tool bag to work your muscles if you can't pull those out.This is what I am talking about tool to pull carriers out
I will come round an pullem for you. £500 (per fuse)
Need to give them a good spray with WD 40 , then slowly wiggle top n bottom , while pulling , just take your timeI struggle with pulling the older fuse holder in consumer box. Is there a tool for this
I have had a few problems pulling Wylex fuses !They are designed to be pulled out by hand. Generations of housewives before you have managed.
Reply to Fuse puller in older consumer box in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
