Fuse Seals | on ElectriciansForums
Discuss Fuse Seals in the UK Electrical Forum area at ElectriciansForums.net
UK
Newbie Question:
What’s the general consensus with cutting the main fuse seal for a consumer unit change? I’m aware of the requirement to contact the DNO, but just wondering what the done thing is in practical terms?
The logistics of getting the DNO to cut the fuse can be impractical, especially in the current climate.
If you are getting permission, how are you going about it?
Newbie Question:
A pair of side cutters usually does the biz foe me
[ElectriciansForums.net] Fuse Seals
Reply to Fuse Seals in the UK Electrical Forum area at ElectriciansForums.net
The last couple of de-loops that I have been involved with had the single phase supply replaced with a three phase cutout (as I believe the DNOs...
I would have to agree with @James to hire an electrician to measure the voltage coming in to the panel. If you have 240vac phase to phase then you...
