Fuse size | Page 2 | on ElectriciansForums
Discuss Fuse size in the Australia area at ElectriciansForums.net
J
Jimmyb
Just wondering after doing a job today, what is samllest fuse size you would use for sockets in a kitchen if there wasnt a washer or dryer in there ?
I put a 32a mcb with 4 double sockets and a single and when all finshed i did think with the loads present surely a 25 or 20 mcb be ok. I always had drilled into me 32 for kitchen no less for years even if there is no big app.
why not just break the ring and turn it into 2 radials?, if you have a ring on l + n but 2 radials on cpc, where are you getting your R1+R2 from?
Because I knew where the break was, I knew it wasn't a hazard as it wasn't current carrying and it was safer and easier to leave it intact
R1&R2 measured and recorded as per radial, offending socket removed and blanked so all remaining had continuity
Reply to Fuse size in the Australia area at ElectriciansForums.net
Well another week passed and I still don't have a proper answer to where the process is wrong. To reiterate, this is not a question for a real...
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
