fuse wire safety recall | on ElectriciansForums
Discuss fuse wire safety recall in the UK Electrical Forum area at ElectriciansForums.net
Reply to fuse wire safety recall in the UK Electrical Forum area at ElectriciansForums.net
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
Its important to remember that a plug top fuse is just a rewireable fuse that's convenient to change and shouldn't be confused with a HRC fuse...
I wonder if someone was putting in glass fuses? Would be interesting if anyone on here has that type of meter and can look at the fuse to see...
"A catalogue of errors" would be the appropriate phrase here and I agree with Avo and James that HSE need to be involved rather than this forum...
Better/Smart/intelligent/expensive generators require two earth spikes set ~10-15m apart. They check the resistance between spikes and will...
