Fuseboard change advice on running the pyro cables into the board | Page 2 | on ElectriciansForums
Discuss Fuseboard change advice on running the pyro cables into the board in the UK Electrical Forum area at ElectriciansForums.net
London
I have a fuseboard change I need to do soon
I’m putting in a FUSEBOX 7 or 10 way RCBO+ SPD
My only concern is how I should run the pyro cables in the board. The board is in a small cupboard in the hallway. I know cables that are not in enclosures need to be double insulated as the pyro cables are in the small cupboard can I just run them straight into the board or do I need to add some conduit , copex etc
I think he's concerned they might not reach the new board given there looks to be no play whatsoever. Maybe a metal adaptable box could be used to provide a fully maintainable join above the new board or as you say 5 couplers.
Reply to Fuseboard change advice on running the pyro cables into the board in the UK Electrical Forum area at ElectriciansForums.net
Given that, it probably makes sense to TT the shed, unless you can be sure it doesn't act as an extraneous-conductive-part. (The SWA won't have...
What I find a little bit interesting is that there was an era of MFT's e.g. Robin, early Kewtech that tried to do non-trip loop tests using D-Lok...
