Fuseboard change advice | Page 2 | on ElectriciansForums
Discuss Fuseboard change advice in the UK Electrical Forum area at ElectriciansForums.net
London
Don’t do many fuse board changes, but what’s everyone’s preferred method, as I see people without labelling the old cables swap boards connect up neutrals and earths then leave line conductors last but how do they make sure each correspond to each other so you can identify the circuit like the 1st Line conductor should correspond to the 1st neutral and 1st earth
I use flags and sharpie during the initial circuit testing after identifying what each cable supplies. Old boards tend to have multiple circuits on one fuse which in some cases require splitting onto separate mcb’s . I connect each circuit L N CPC A circuit at a time. Not sure if its the quickest but it works for me.
Consumer units are easy enough;
Dress in the neutrals, earths and then lives which have already been numbered up.
For dbs all depends on the layout..
Usually I will cut all the cables to the same length, number up the cores with wago push ons and then dress in as I go along..
The last few boards I’ve done have been bespoke ones.. Got an enclosure and populated with breakers, contractors, etc all mounted on din rails
Reply to Fuseboard change advice in the UK Electrical Forum area at ElectriciansForums.net
Ok I’ll try this when I’m down
And exciting when that Hager AFDD finally tripped 😂
nicebutdim
N
